newbie....tune up on a 12v what do you guys reccommend
i'm wanting to perform my own tune up on my 1996 12v can you guys tell me what i should do and if i can actually do it myself
thanks appreciate it!!
Miles? Definately do plugs, wires, and air filter.
Depending on miles you might want to do the fuel filter (PITA on a Quattro). Also check or replace your vacuum hoses. If they are original, might as well replace them.
With the possible exception of the fuel filter, you should be able to all this yourself. Just don't overtighten the plugs.
Good Luck.
Good Luck.
I would recommend the OEM NGK plugs and OEM Bremi Wires.
You're probably right at the point where you should do the fuel filter, too. I did it myself and there is a write-up on it in the archives but it is a PITA.<ul><li><a href="http://www.germanautoparts.com">Get them here...</a></li></ul>
LIST
078-115-561-J (oil filter)
n-013-849-2 (drain plug seal)
101-000-035-hj (plugs)
058-133-843 (air filter)
G11 coolant
b-000-700-a1 (brake fluid)
8a0-819-439-a (pollen)
441-201-511-c (fuel filter)
1 set magnecor electrosports wires
G11 coolant
Changing cabin filter, air filter, spark plugs, anything I'm missing? Should I change the fuel filtr
KingA4
01-12-2004 12:31 PM
A6Gary
Audi 100 / A6 (C4 Platform)
10-28-2003 08:08 AM
JT
04-05-2002 07:46 AM
