NO: Breaking system: Soft pedal and an “internal piss-like sound”
NO: Breaking system: Soft pedal and an “internal ****-like sound”
When I press the pedal, I can hear a pissing sound inside somewhere, and I never get any real firm brake. Must be remaining air despite I have bled the system with VCDS. No air bubbles do occur during any bleeding anywhere.
This is the ESP ABS I have, the same as in A4, RS4 and A6 C6.
Sounds like a defect master? I get firm pedal once I have pumped it up, and it stays, no sinking. When I let it go, the brake is too soft again next time.
The sound makes me think that your brake booster is leaking (vacuum) but symptoms sound like a master, like you said. Does it feel like you need more pedal pressure to stop, once you get it pumped up?
I looked into this and apparently master cylinders for an ESP system are different than for non-ESP. I think there is a brake pressure sensor in the ESP masters. I'm out of my league here with this question but perhaps you need an ESP master.
The hydraulics might be slightly different however, but I think that only the fittings differ, and that my master is blown.
I hope so, too. Fingers crossed!
I just bought a new master cylinder (Mayle) for my '96 B5, Blueberry. It has the sinking pedal.
While working with brakes, one press on the pedal beyond the normal brake range can damage the dealings in the master. Regarding the huge work I’ve made with this car (all brakes are new, and break lines except the longitude original aluminum) I should had spent 50 USD more on a new master just being safe. Stupid not doing so.
