Noob Oil Change question - Resetting Oil Service light
From the Noob FAQ:
"28. How do I reset the oil service interval light w/out the use of a VAG-Tool?
With key in the off position, push and hold in both clock and odometer stalks, start car. That's it."
My clock stalk does not seem to push in. Following this proceedure did not clear "service OIL" from appearing in the trip odometer screen.
It's a 1998 2.8 30v
No, I did not buy a service manual yet.
It's a 1998 2.8 30v
In order to "re-read" I would first have to read... But THANKS! it worked
I pulled the quote that I posted off of an AW Noob FAQ. I had not yet seen the tech article you linked to. That procedure did the trick. Thank you, Ed, I appreciate your help.
AW is an awesome resource. I usually STFA before posting a question. Thanks to everyone who posts helpful info here.
Cheers!
Cheers!
