is this normal???...
Old Apr 26, 2000 | 04:08 PM
silver surfer's Avatar
New Member
Default is this normal???...
my new 00 1.8qm is going on about 2k miles and ever since i had it, in the morning, or on the first drive after a long time the car was parked( around 12 hours) when i start the car and put it into 1st and very slowly make a hard right turn to get out of my parking spot, i hear a rather high pitched squeeking noise. is this just the fan belt not being warm enough? i'm in boston so we're having real crapy weather for example today that would be april 25 and it snowed and its about 8 degrees with wind chill!!! could this be a problem? or should i get it checked out to make sure its not my front axel or suspension? the thing is after that initial first 3 seconds then all is fine until the next drive after a long layover.
any comments are appreciated.
thanks
Old Apr 26, 2000 | 04:52 PM
atolch's Avatar
New Member
Default Yes, get it checked out. The possibilities include bad power steering pump, low fluid
in the power steering reservoir or just a loose belt. Or it could be something entirely out of the steering system. But it's not normal.
Old Apr 26, 2000 | 07:40 PM
New Member
would a check up on this problem on my car be covered by warranty? even though it hasn't been 5k?
Old Apr 26, 2000 | 07:41 PM
DavidW's Avatar
New Member
Default Check the level of the power steering fluid...
if it's low, fill it up with the recommended stuff and see if it stays filled. I had
the same symptoms as well as a groaning sound from the power steering
pump. Turned out to be a bad steering rack, which Clair (I'm in Boston,too)
replaced in about a week. My car was about a month old with a couple
thousand miles.
Old Apr 26, 2000 | 07:50 PM
DavidW's Avatar
New Member
Default Yup (more)...
5K is the interval for your free scheduled maintenance. Warranty covers problems anytime up to 36 months or 50K miles, its not just a checkup
because you've discovered an actual problem.
Old Apr 27, 2000 | 05:25 AM
Donkihad's Avatar
AudiWorld Expert
Default I live in Boston, and have exact same thing!
The fact that it goes away after first turn make me think it might be the dry rubber friction against the wet road!!!! (It has been wet here for about a year...j/k)Anyone else have any ideas?<p><A href="http://registry.audiworld.com/audi/registry/details.asp?car=4586">
<img SRC="http://members.bellatlantic.net/~theos2/signature.jpg"BORDER=0></a>
Old Apr 27, 2000 | 07:35 AM
dougie's Avatar
25 Year Member
i have heard this too, but only when i have a passenger in the car with me. its embarrassing.
net1994
A4 (B8 Platform) Discussion
17
Dec 16, 2020 07:35 AM
Blea408
S4 (B8 Platform) Discussion
Jan 12, 2016 01:47 PM
NR04
13
Aug 30, 2012 08:45 AM
Avantadrive_Original
Jan 16, 2009 08:18 PM
syhilly
Audi 100 / A6 (C4 Platform)
Oct 13, 2004 07:53 AM
