not mandrel bent?
it's not but since it's 3"EVERYTHING it very likely flows as well as 2.5-2.75"+ or better
Build a turbo-back one-piece 3" SS downpipe with flex-joint for me like this and I'll buy it tomorrow even with compression bends instead of mandrel bends if done in 3". I'll do everything from the cat back here as I have a used MTM slip-joint back exhaust just sitting around
And I hear he didn't throw any codes yet with only one 02 sensor... AMAZING!!
Re: not mandrel bent?
It looks like it could be a bunch of mandrel bent U-pipes and elbows cut up and welded together as I've seen done for makeshift mandrel bent exhaust systems.
The bend after the flex pipe doesn't look like a normal press-bent pipe though it could be the light and that there are two pipes welded together at that point. However, if it were press bent, why would there be two pipes welded together there int eh first place?
PhunkFX
10-07-2007 08:10 AM
Regenmeister
10
08-09-2005 05:19 AM
How much did you pay for someone to make a custom flange for your Cat to your AM Exhaust?*4 picutes*
NW Avant
04-05-2002 02:04 PM
