OBD failure
2000 Audi A4 1.8T Avant, factory (non-bose) radio.
The car works, no CEL. Normal operation.
No connection with VAG-COM or inspection station to ECU or any other module.
Disconnected ABS unit, still no joy.
Using multimeter on K-line to ground gives about 40 ohms. (Seems like about 100mV DC when measured for voltage.)
Any ideas on what to disconnect next to find out what's causing the problem?
Thanks for your thoughts.
Having said this, our Hex-Can-Com cable hooks up 100% of the time now. You might consider getting your car inspected privately by a facility that knows the mark. State run inspection stations are usually filled with butchers who don't have a clue(about cars or inspections, political appointees).
