offset?
Old Mar 12, 2009 | 07:49 PM
pjpeckweck's Avatar
Default offset?
does anyone know if you can put a 19x8 rim in the rear of a b5 with a offset of (et45)? without spacers thanks
Old Mar 12, 2009 | 07:52 PM
Nate (ETKA+Scumbag)'s Avatar
Keeper of the Cash
Tech Guru
Default No
I say that simply because they are 19" wheels.
Old Mar 12, 2009 | 07:56 PM
pjpeckweck's Avatar
Default well
i currently have 19x8.5 with an offest of et35 and their fine, just wondering about the et45
Old Mar 12, 2009 | 08:03 PM
Silver Streakin''s Avatar
Member
Default why would that be an issue? rolling diameter would be the same, assuming he uses the right tires
x8" wheel with +45mm is fine.
you can run 8.5" with +35mm, if you're not too low.
Old Mar 12, 2009 | 08:09 PM
pjpeckweck's Avatar
Default silver streakin
thank you, i really needed some help with this issue, i currently have 19x8.5 with et35 on 225/35/19 with h&r coilovers. i was looking at new wheels but the guy from axis said i would need 10mm spacers because the new wheel is 19x8 with et45 offset, he said the inner lip will hit the coil springs???? pls. help thank you
Old Mar 12, 2009 | 08:18 PM
Keeper of the Cash
Tech Guru
Sounds likes you were told exactly what you need to know.
Guest
Guest
Posts: n/a
Another example.
Old Mar 12, 2009 | 08:21 PM
Keeper of the Cash
Tech Guru
Opinion /= fact.
Member
Default ask in the wheel forum, but I don't see why you'd need a spacer for a tire that is the same size
overall as a 225/45/17 that is stock.
and stock is +45mm on most of the stock wheels. +43mm on mine. +35mm on aftermarkets.
there are ppl running 235/40/17 Rcomps on 17x8, +35mm wheels granted, I don't run my car too low, which helps with rubbing... as well as rolled fenders and taking things slow on the street.
Keeper of the Cash
Tech Guru
Oh, and what are you going to do about it? You've tripped up trying to "get me" before you know.
