offset?
Old Mar 12, 2009 | 08:26 PM
  #11
pjpeckweck's Avatar
Default thank you silver streakin
i rarely post threads here, thanks for your help, not like other people that have nothing better to say.
Old Mar 12, 2009 | 08:29 PM
  #12
Silver Streakin''s Avatar
Member
Default no problem. I would still do some research, though. too bad the search function is down.
but, common sense tells me you'd be fine.
I'd be more worried about your 8.5", +35mm wheels not clearing -- but, if those are fine... then I don't see how the x8, +45 setup would be an issue.
Old Mar 12, 2009 | 08:33 PM
  #13
pjpeckweck's Avatar
Default your right
im just not too familiar with offsets on wheels do you? i believe the guy said the inner lip of the rim might hit the coil springs.
Old Mar 12, 2009 | 09:01 PM
  #14
Guest
Guest
Posts: n/a
Default You come across like....
<ul><li><a href="http://www.youtube.com/watch?v=kHmvkRoEowc">http://www.youtube.com/watch?v=kHmvkRoEowc</a></li></ul>
Old Mar 12, 2009 | 09:02 PM
  #15
Guest
Guest
Posts: n/a
Your opinions tend to be wrong... you should work on that.
Old Mar 12, 2009 | 09:15 PM
  #16
S4iowa's Avatar
AudiWorld Expert
Default If you're running a 8.5 with ET 35 today and go to a 8 with ET 45, you'll decrease your inside
clearance by 4mm. Look to see how much room you have to the inside of the wheel/tire to the shock/spring right now.
Check the calculator.<ul><li><a href="http://www.1010tires.com/WheelOffsetCalculator.asp">http://www.1010tires.com/WheelOffsetCalculator.asp</a</li></ul>
Old Mar 12, 2009 | 09:17 PM
  #17
S4iowa's Avatar
AudiWorld Expert
Default You'll also note on the calculator that you've moved the outside of the wheel in 16mm
so if you want it to look the same with the wheel to the outside close to flush with the fender, you'll want 15mm spacers.
Old Mar 12, 2009 | 09:26 PM
  #18
S4iowa's Avatar
AudiWorld Expert
Hey, check the link above for your answer.
cpt_huynh
Q5/SQ5 MKI (8R) Discussion
Nov 30, 2015 05:54 AM
jlzhisname
16
Jul 5, 2005 08:15 PM
TTALMS
Aug 4, 2004 05:15 PM
Milpitas2.7T
15
Jul 13, 2002 08:17 AM
Milpitas2.7T
Apr 27, 2002 07:18 AM
