Oil Dipstick Funnel Insert
You can buy it at your dealership. It's not very expensive at all...
Or you can order it online. But you'll need to know the part #. What Year car and engine model do you have. I'll give you a part # now.
Seems like a common failure, I broke the oil dip stick handle. It must be from the heat in the engine bay.
jaime
jaime
Re: You can buy it at your dealership. It's not very expensive at all...
Mine is A4 1.8T Year 2000
Yes, that's a common problem. I already replace the handle too.
Thanks for the Part No.
A few bits of plastic won't hurt (more)...
... if it drops down in there - it'll get pulverized in the crankcase. It's impossible that it could foul the oil pump, either. No worries.
I pulled the valve cover off a 16V GTI once & found a dozen or so plastic oil container cap "rings" sitting there on the windage tray. Nice.
