Oil sensor
Old Jan 13, 2014 | 10:50 AM
Jgarcia1910's Avatar
Default Oil sensor
Okay car started saying. Oil sensor in the center dash.
Old Jan 13, 2014 | 01:54 PM
twentysevenlitres's Avatar
Tech Guru
I take the it you've checked your oil level on the dipstick?
May be a sensor fault - only VCDS will tell you.
Old Jan 13, 2014 | 05:30 PM
Prospeeder's Avatar
1.8T engine? Is it Red or yellow? If its red, its oil PRESSURE, if its yellow its oil level. If its red, it has low oil pressure. If its a 1.8T, you need to stop driving it immediately and have the oil pan removed and the pickup tube cleaned out or replaced, and bearings checked. It might seem ok, and have full oil but it is not lying or a bad sensor, its a known problem and at higher rpms it starves the engine and turbo of oil and causes damage. I always replace the turbo oil feed line from the oil filter housing because it too can carbon up and cause turbo failure.
Old Jan 13, 2014 | 10:09 PM
M.S.G.'s Avatar
Just had to have mine replaced. Yellow oil sensor warning come on. No temperature reading on the oil gauge, but water temperature was normal. This is the best replacement according to my shop.
http://www.ecstuning.com/Audi-B5_A4-...sor/ES2618895/
Old Jan 14, 2014 | 07:04 AM
Yea that sounds like my problem exactly I'm gonna replace it this weekend. That part is located at the bottom of the motor on driver side right ? And yes guys it's 1.8t. I think it's yellow hard to tell bc semi color blind.
iowaan
18
Dec 30, 2017 07:56 AM
hardipk5
17
Nov 24, 2015 03:42 AM
abpuma
Sep 17, 2015 11:39 AM
ay6
Sep 11, 2015 03:47 PM
Clarkbowman
Audi allroad
Sep 10, 2015 05:46 AM
