OK got a problem... Cylinder misfire in cylinder 1 and fuel level too low
time to buy parts. what do you think is the reason for the misfire. it couild be a bunch of thins, plug,wire,injector, mass air, coil, this sux, and what would be for the fuel level too low.(yes theres gas in the car) 98 2.8tq 30v .gonna go the the Stealership and buy parts (got a friend in the parts dept) just need to know what to buy. TIA
well I would start cheap....
first...put the plug from cylinder 1 into another cylinder and see if the misfire follows. If not, do the same with a coilpack. If it doesn't follow the coil pack, it could be your ignition control module.
As far as fuel, check your fuel filter, see if its clogged. Run some techron through there, maybe something is gummed up. Don't just throw parts at the car thinking that will fix your problem
carterleeds
9
08-08-2013 12:48 PM
geoff_k
14
08-13-2012 03:22 AM
