OK i need help...weird noise coming from the front passenger side
Its like a scrape noise comin from the front end on the passenger side. I dunno what the hell it is. And it only happens when i go about 40mph and when i break. WHAT the hell is it?!?! thanx for the help guys.
Yes =) check your right front brakes to see if anything is rubbing the rotor.
other than that, how worn are your front pads? does it sound like it's coming from the brake/wheel area, or is it a plastic scraping sound? is the wheel well liner secured by both plastic bolts that hold the belly pan in place? perhaps one is missing and the plastic is hitting somewhere. if you can't troubleshoot it yourself, I'd get it looked at immediately by your dealer. no use risking damage down there.
SFexBOY
07-06-2006 03:02 PM
Can bad wheel bearing make grinding noise...sound like when you sharpen a knife, seriously need help
kookie
11-13-2005 10:48 AM
