Ok. Update on my engine problem:
Old Apr 24, 2002 | 08:52 PM
bugbbq's Avatar
Default Ok. Update on my engine problem:
When the problem happens, it's happening consistantly.
In 3rd gear under WOT, the psi caps @ 13psi. Power level drops and is peaked until pedal is off of WOT.
4th, same thing, only the PSI caps at 10psi
5th, same as 4th.
1st and 2nd are alright. Launches are smooth, with no power loss. 2nd will lose power if I'm at lower rpms (about 1000-1500rpm).
tomorrow is my day off, so i'll check and re-check all the vac lines.
Grr....this is so frustrating.
Old Apr 24, 2002 | 09:05 PM
Andy_FL's Avatar
25 Year Member
marmot chewing up the vacuum lines. take it to the stealership ASAP!
Old Apr 24, 2002 | 09:13 PM
bugbbq's Avatar
Default well...if it is the vac lines...
at least THAT would be covered under my T-belt warranty!
Old Apr 24, 2002 | 11:42 PM
WYSIWYG's Avatar
doesnt exactly sound like the MAF, but clean it anyway
Qendrimsh.
Sep 6, 2018 07:33 PM
mattarios2
Aug 31, 2006 05:23 PM
KO4ed in Phoenix
Oct 3, 2003 09:11 AM
DavidFeygin
10
May 19, 2003 03:51 AM
MagicTT
Jul 24, 2002 10:04 AM
