:Old school guys: : Stripped my thermos. housing thread, Cant helicoil it....... Help!
#21
Should stay in spec for quite awhile once set and heat cycled a time or 2
Tim ran a solid lifter setup for a year or more and never had a problem with having to re-adjust valves once set and settled.
Off subject, but why did you decide to go solids? To have some extra headroom for the track, or do you need it for powerband? If powerband you must be running a GT40. IME the GT30 is done (as far as HP peak) at 7600rpm on my car and Tim is done at 8200rpm on his GT35. Shrick and Piper both have valvetrain setups for hydraulic that wind with no problems to 84-8500. Just curious as to why you went this way as it is much more expensive. Were you floating valves w/hydraulic?
ATKS4
22
10-22-2007 02:31 PM
cjk
Pacific Northwest Discussion
12
05-11-2007 05:32 PM
HELP!!! HOW DO I GET OUT A STRIPPED 6MM HEX BOLT? Im really stressing cuz I cant get it out. Its the
poopeter-el sigthief
11-14-2002 02:54 PM
