other than alignment could bad cv joints cause unever tire wear in front?
i had an alignment last fall after i replaced my tierod ends and today i noticed that my front dr side tire was quite worn on the inside i have not noticed any noise wheel does not wiggle like when my wheel bearing went out.. any thoughts i will go and check the cv boots i guess as a next step...
just crawled alittle under on my lunch break and saw the driver side cv boot is ripped..
and it looked like oil was either leaking out some or had leaked out in the past..
so i guess i need atleast a new boot for both sides nd probly a new joint for the driver side.. Anyway to tell if the joint is bad before removing the parts?
Thanks ..
Oh and HOw much for a CV joint... i read that oem ones are about 300 and some after market ones about 90 or so is this still the rates? any thoughts on oem or aftermarket?/
Thanks ..
Any estimate how long had it had been rip? My is about a month before I replaced it ....
and the joint seem to be great. They are not that easy damage unless you have lot of sand in there. Just replace the boots, $21 for the kit. Very easy.
ok thanks ..
how do you tell if the joint is actually bad? i have no idea how long its been like this atleast a couple months since i had it up on a lift last and checked everything out..
Also, if you just replace the boots...
make sure to clean and regrease the cv joint very well before putting the boot back on. I believe there's a tech article on it.
Only way I know of to tell if the joint is really bad is if it ticks/clunks when turning. SO give that a try, and if it's silent, just replace the boot and you *should* be good
Julep1
07-05-2017 06:59 PM
rossej
12
04-29-2010 06:00 PM
lithium15
12-24-2004 12:49 PM
Big Ern
01-04-2003 11:29 AM
