overboosting - if my wastegate is stuck closed...
1.8T, tip, APR v3, forge bpv
Symptoms: Car is overboosting. When getting on the gas (in drive), the boost hits about 1.25 bar and starts to misfire. Throws CEL (Cyl 1 misfire, Multiple misfire codes). Goes into soft limp mode for awhile (limits at .5 bar) until I completely back off the gas, then I get get it to overboost again.
I checked the vac hoses between the N75 and turbo and they seem fine. I also checked all the hoses around the N249, the L hose, and the hoses around there. The wastegate rod doesn't move, so it's not broken. While checking for broken hoses, I did find a coolant leak, but nothing to do with vac.
If the wastegate was stuck closed, or my N75 was bad, I would be boosting like crazy as the RPM's climb, even in park. Sounds like I can eliminate a bad wastegate, bad N75, or the hoses around it, correct?
My N249 isn't bad, because I can hear my BPV opening. I would think that if it was bad, I wouldn't hear it opening at all...
There's a check valve that looks like it's starting to melt, but it doesn't look like it's leaking yet.
I'm going to log blocks 114, 115 and 003. I tried to do it today but my laptop battery died.
Any other suggestions???
change your plugs, gap them to .030 or .028, if it doesn't go away play musical coil packs...
i'm having the same issue and the misfires follow the coil pack, so i'm replacing the bad one.
BKR6E's installed a few weeks ago trying to fix misfiring
the old plugs still looked good.
you bring up a good point. IIRC, before I changed plugs I think the misfire was on #4, now it's on #1. I swapped the order of the coil packs randomly.
I'll use vagcom and count the misfires, rotate coil packs and see what happens.
tx!
tx!
Still pondering on low or no boost on my car..Hoses looks ok.Can a broken DV or N75 caused it??.....
Bolo
07-08-2007 03:04 AM
NevaFolow
06-14-2007 03:03 PM
kday
Audi Original "S" Cars
9
01-01-2006 09:44 AM
twoquattros
08-07-2005 07:39 PM
