Is the piston size the same in the a4 and s4 rear calipers? I have read that they are a direct swap-
vented rear would be nice. I will have stoptech's in a few months-- will the smaller a4 master cylinder be an issue? Thanks
The piston size is nearly identical, if not the same...
I just went through this issue. See my sub posts on a couple of braking threads.
The bottom line is that the piston diameter is close to the same, but the rebuild kits are different, so I'm not sure exactly how different they are. The OEM pads for the S4 are slightly different (different part number), but the backing plate is the same size. Some aftermarket pad manufacturers don't differentiate between rear pads for the A4 and the S4, others (and Audi) do.
The rotor diameter and width is different (A4 = 245x10mm, S4= 256x22) the width is obviously different due to the venting, which makes the caliper different to accomodate the wider rotor, and the carrier is larger to move the caliper outward. You need the S4 dust shields as well, as the rotor size will cause rubbing, even though it's only 11 mm larger in diameter.
Basically, if you can get your hands on a full S4 rear setup, it's a direct bolt on swap.
S4 rear brakes vs A4 rear brakes <-search terms.
That's one (complicated) way to do it.....
<ul><li><a href="https://forums.audiworld.com/a4/msgs/1957982.phtml">https://forums.audiworld.com/a4/msgs/1957982.phtml</a</li></ul>
exSVT
A4 (B7 Platform) Discussion
09-18-2007 09:30 PM
Silver Streakin'
02-05-2004 09:09 AM
Steveo369
02-04-2004 11:43 AM
NYCa4
01-23-2003 01:26 PM
Brake Help
11-03-1999 12:19 PM
