please help .. asap.thanks
removing the ECU a few minutes ago...going at the back screw with a tool which holds other rench heads in it..well it popped open and one fell out..if you are facing the windsheild straight on so its your 12 o'clock it fell to the left of the ECU down into a gully type deal,,it did not fall through to the gronud..any suggestions on removing? and how harmful is this
That could be one of the two plenum chamber drain valves
If they get clogged water can't get out of the plenum chamber. I'm not sure how thin the actual drain hose is, so I don't know if you can push the screw through the drain with something thin, long, and flexible. Maybe you can stick a magnetic pick-up probe dow the drain valve? With a little luck you can fish the screw out.
try getting one of those extendable magnets
i've dropped plenty of screws into my engine bay. they usually end up on the plastic pan at the bottom. try the magnet or try popping the plastic piece off.
mny
Audi A3 / S3 / RS 3
01-19-2007 09:29 AM
shrtbus(w/ cq)
02-04-2004 09:10 AM
iikwanii
01-24-2003 06:35 AM
heelu
05-06-2002 12:23 PM
