Please help with rattling noise from engine bay
I have a 98.5 1.8TQM and I have this strange metallic rattling noise which seems like it's coming from around the cat. It sounds like dragging a piece of thin metal along a cement floor. I just installed a borla exhaust so would an exhaust leak sound like that? I checked my heatshield and it's not loose. Thanks in advance.
check the DP/Cat...
I installed my Borla early this summer and am experiencing the same issues. I get a chirping noise when starting from a stop then a metallic/loose heatshield niose when the engine is under load. The post below got me to go check the exhaust mainfold and I had my dad watch the cat/dp as I reved the motor. Around 4K RPM you could see moisture escape between the cat/dp. Guess I should have put a new gasket in when I installed the exhaust... time to place and order w/ ECS. BTW, the noise wasn't as noticeable outside the car with the hood up as it was from within the car or driving w/ the windows open.
stusaudi
08-17-2008 03:43 PM
A4in_tha206
A4 (B7 Platform) Discussion
07-18-2008 03:05 PM
F1fanatic
04-17-2003 01:47 PM
KaMaKaZieP -ALUMIN8-
Audi 100 / A6 (C4 Platform)
07-02-2002 06:16 AM
