Possible solution for ISV stalling problems.
Old Mar 2, 2005 | 12:21 PM
knerml1's Avatar
New Member
Default Possible solution for ISV stalling problems.
I had encountered the typical idling problems attributed to a dirty/faulty ISV.
However, when I went to pull mine from my 1996 V6, I found that the unit was loose.
There is a plastic(hard rubber?) block between the ISV and engine. This block had compressed over time, resulting in a loose ISV.
I replaced the three original nuts with stainless steel nuts and split washers, in case it become loose again.
Suggest simply checking to see if the ISV is tight, before pulling or replacing unit. Also suggest checking the torque of these nuts every two years.
Old Mar 2, 2005 | 12:43 PM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
I know in my case, the nuts and ICV were plenty tight before removal...
Old Mar 2, 2005 | 03:13 PM
sephir's Avatar
two of my three nuts were loose - good suggestion ;-)
Old Mar 2, 2005 | 03:17 PM
Head Cat Herder
25 Year Member
Default You have 3 nuts?????
Freak :-)
So, yours were loose? Strange, the ones on our old car were pretty snug, I actually had to peel the ICV off of that rubber block.
Old Mar 3, 2005 | 06:04 AM
sephir's Avatar
Default Re: You have 3 nuts?????
yeah, maybe the last owner didn't tighten them down. at least it made it easy to remove!
QuattroJay
Dec 14, 2008 03:16 PM
kTTang
Mar 19, 2008 05:46 AM
TonyOldSchool
Dec 7, 2004 06:32 AM
Audi-Impaired
Apr 12, 2003 09:48 AM
computrtutr
Oct 8, 2002 07:14 AM
