Power window BT: Common parts to replace....?
Andy
https://forums.audiworld.com/a4/msgs/2715488.phtml
Just replace the parts labeled 'cheap plastic' with the A6 pink plastic/metal parts( few bucks each). You will need to modify the parts by filing and screwing on a piece of 1/16" flat stock. But the results are great.
Only replace the entire regulator if you aren't willing or able to do the above repair.
I use my windows a LOT, so it's something I don't want to take the chance getting stuck somewhere with an inoperative window. In the grand scheme, I would rather spend $100 up front on something that has been prone to breaking, in various places. From my archive search, it's not just the clips that break, apparently the pulleys can fail as well.
I'm more than willing to do the repair, just not willing to do this repair <b>twice</b>.
Andy
My comment about changing the clips is merely to warn you that you will have to make some homemade modifications to the parts. Many people don't want to do that or are unsure as to how to proceed, and would rather just change the assembly to be on the safe side, or to save time.
