Problems installing a compass
Old Sep 17, 1999 | 02:34 PM
Bill S.
Guest
Posts: n/a
Default Problems installing a compass
I'm trying to install a small compass but having no luck. The (inexpensive) compass has compensators, but not strong enough to correct for the fields inside the car.
With a little experimentation I've determined that the operation of the engine, climate control, radio, etc. are not the problem, as I first suspected. If the compass is anywhere forward of the front seat backs (approximately), it is wildly inaccurate. If it is in the back seat, it is quite accurate (as it is when outside the car). Turning on the engine makes little difference. If I had eyes in the back of my head I'd be all set.
Anyone have better luck with a compass installation? Are there better compasses that can accurately compensate for the apparently strong magnetic fields in the front seat area? Any other ideas?
Old Sep 17, 1999 | 02:40 PM
A. Udi
Guest
Posts: n/a
Are you going to float it?
Old Sep 17, 1999 | 03:01 PM
PT
Guest
Posts: n/a
Default Mine works great . . .
It's made by Precision Navigation. I got it from one of those ubiquitous mail order gadget catalogs.
With the supplied double-sided foam tape it mounts perfectly on the colored trim just below the left side air vent. After calibration to adjust for the car's electro-magnetic fields (takes about 45 seconds) it works very well. It also has the indiglo-style backlight. It costs about $50.
Old Sep 17, 1999 | 07:19 PM
Bill S.
Guest
Posts: n/a
Default Precision Navigation compasses
Thanks for info. I checked out their web site. Which model do you have?
Old Sep 17, 1999 | 07:29 PM
Bill S.
Guest
Posts: n/a
Not sure what you mean
Old Sep 17, 1999 | 09:23 PM
A. Nelson
Guest
Posts: n/a
He means are you thinking of going sailing in it?
Old Sep 18, 1999 | 12:12 PM
PT
Guest
Posts: n/a
It's the basic model (the manual says ML 78)
DudeDah
Feb 1, 2025 05:34 PM
RallyVermont
Jul 31, 2007 04:25 AM
Audi Advocate
Dec 20, 2006 04:58 AM
hsm
Oct 22, 2001 08:19 AM
Rick (Virginia)
Nov 7, 1999 11:26 PM
