Pulled 6 vag codes... need help mostly o2 sensors i think
Ok, imho my car could be running better. It is a 97 audi a4 quattro with the 2.8 12v V6. I ran a vag scan and i pulled 6 codes.
The o2 sensors I am guessing need replacing. which sensors are these? I was thinking of following this http://forums.quattroworld.com/12vv6/msgs/1317.phtml since they are cheap, but i wanna make sure those are right first.
I got some NGK+3 on the way, so hopefully that will fix the misfire, i will have to check that wire also though. are there any other suggestions with that?
The air leak code, could that be related to a vacuum leak? I am gonna pick up some new vacuum lines from bmw just to be safe, but i am not sure if it could be anything else.
I have no idea about this one 00532 supply voltage???
I am guessing that the fuel level too low just means I cut it too close in between fill ups.
I appreciate everyone's help. thanks a ton.
CODES PULLED
17514 P1106 Bank 2 Probe 1 voltage too low/air leak
16540 p0156 o2 sensor circuit, bank 2 sensor 2: malfunction
16520 p0136 o2 sensor circuit, bank 1 sensor 2: malfuction
17658 p1250 fuel level too low
16688 p0304 cylinder 4 misfire detected
CODES PULLED
AdL33
03-29-2008 08:58 AM
q2quest
12-26-2004 02:47 PM
ThirdEye
04-12-2003 11:25 AM
