question?
Old Jun 23, 2005 | 01:21 PM
IBG's Avatar
IBG
Default question?
I posted over the weekend about boost leak problem I had. It would hold at 18psi for 2 second then drop slowly to 5psi. then the next day it would hold for like a second then drop quickly. I have't been over 5psi for about a week, so today after work I did two 3rd gear pulls. On the first one it held all the way through at around 19psi. Then the second one held at 20psi then droped to 18psi. Then I did a 2nd gear pull and it was holding at 18-19psi and then slow dropped down again. So what could it be? that is causing it to do this. leak? wastegate(hopefully not!)? bad dv(I have a hyperboost)?
Also I had my neuspeed exhaust installed last week and the guy cut the old exhaust and and pull out the downpipe and cat, so could it be a problem with an O2 sensor?
Old Jun 23, 2005 | 01:27 PM
Zed 2.0's Avatar
Default can't explain the 18-5 variation, but the 20-18...
is totally within the limits of normal boost spiking.
Old Jun 23, 2005 | 01:29 PM
IBG's Avatar
IBG
Default I know the 20 to 18 is normal, but
why would I be loseing boost a week ago and then holding fine and then loseing it again?
Ochlockonee
Apr 15, 2006 11:32 AM
Nasti00S4
Nov 12, 2005 07:46 AM
01Raven225Coupe
Jun 3, 2005 09:48 AM
Vodka G
Jun 3, 2005 05:05 AM
holychild666
Sep 23, 2002 01:53 PM
