question? you cant put more than 14 psi in a ko3 ... or that what tunning
companies say that are putting but the reason is because it will over heat? so if you get a intercooler can you increase that? this question is for any turbo charger.
I think they mean that the turbo is overspinning and getting high EGT's. The K03 can only take up to
1740 temps after that things start to melt. The problem with doing a high boost with the K03 is you cant run the car at wot for a long time. I use 20psi for drag racing, but I do run a 20psi chip on the street. If you do the intercooler you can add more adv timing because the air charge is cooler.
APR has something called EMCS which can control modes in the car...
You can have 3 or 4 different modes. For example, you can have valet, chip, and race mode. This is controlled by the cruise control. It's pretty easy to do and takes a few seconds to change modes.
Something that is even cooler is the home upgrade cable link. This allows you to upgrade through the internet at your home. this saves the trouble of downtime, shipping $$, or driving to the dealer. I should be getting mine this week.
Spin Doctor
04-16-2003 07:10 PM
tberry
05-30-2002 10:42 AM
01A4medfordNJ
11-05-2001 03:33 PM
spdracer53
02-24-2001 04:20 PM
