quick question- hardwiring my radar.. >
I bought solderless "spade-tongue terminals" guages 22-18 & 16-14 from radio shak tonight (part # 64-3031). Which size should I use in fuse #27 (the 22-18 or 16-14)? Also, I assume I insert the "U" or fork shaped spade terminal into the LEFT SIDE of terminal #27.. so that it makes contact with the copper fuse female connectors, correct?
Into the left side...correct.
But you should have bought the blade type connectors, not the spade type connectors.
If you want a cleaner install...search for MarkP's A4 website (I think there is a link under the Links section...Enthusiast Sites). It's not hard...and much cleaner than running wires along the fusebox.
I actually bought these "quick disconnects" too, in case.. >
<center><img src="http://www.radioshack.com/images/ProductCatalog/ProductImage/64/64-3134.jpg"></center><p>
will these be better? (the male one)
(part # 64-3134), "crimp quick disconnects"
shipspeed
06-19-2005 11:09 AM
TTALMS
10-27-2004 05:56 AM
ScottGo
03-15-2003 12:04 PM
