Replacing headlamp lens on 1996 a4
Any advice would be appreciated.
I have removed the two bolts on top of the headlamp unit but the headlamp and indicator assembly seem to be fixed at the bottom. (out of sight and below the bumper. DoI really have to remove the bumper?
What steps do I need to do to get the headlamp out
so I can replace the lens.
Cheers
Andy
Cheers
Andy
third screw below, on the side. No, you dont need to pull the bumper.
the turn signal lenses slide out towards the front, and are held in by a plastic clip.
Remove the corner lamp to access the third bolt.
Hard to describe without a picture, but basically unhitch it, then push down on a tab and slide it forward. If you look back behind the lamp long enough, you should be able to figure it out. Good luck
Andy
Andy
Quattrotrac
11-22-2003 04:39 AM
