Is this right???
Old Jun 28, 2002 | 05:42 AM
Audi[]Viruz's Avatar
Default Is this right???
<center><img src="http://pictureposter.audiworld.com/34413/wiring_harness.jpg"></center><p>Ok this is the wiring harsness that SPP sent me for the e-codes. But there were no instruction. The tech file showns a different harness. Can someone who has install them please give me some info... Thanks
Old Jun 28, 2002 | 05:45 AM
SirScott's Avatar
Default Oh boy, have fun!
You're going to have to cut the yellow lines in half. Then, the clip end will slide into the harness (black pieces on left in that picture). Placement into the harness is in the tech file (though it's not 100% correct if I recall correctly.) You'll have to strip the ends of your current wires, connect them to the stripped end of the yellow wires, and voila, you're all set.
S.
slowpoke's Avatar
that's what I got...not worth what they charge..but I guess its the "accepted norm"
Old Jun 28, 2002 | 05:55 AM
Yea, not worth it at all...
Old Jun 28, 2002 | 06:01 AM
Default So
your telling since I only got 8 wires, and there are 8 holes on the harness I need to split them and make 16 wires. Is that right???
Old Jun 28, 2002 | 06:06 AM
HDClown's Avatar
Default it depends on how you are wiring them
If you want to wire them like they work in europe you need a relay and it requires 4 wires per side. If you want to wire them to be always on, you need half as many wires. There are many options . I'd suggest searching the forum, you'll find out what they are.
Old Jun 28, 2002 | 07:14 AM
Phil type 951's Avatar
Re: yeah its sad... just a total lack of effort... for that price they should put it together...
Old Jun 28, 2002 | 07:22 AM
WYSIWYG's Avatar
agreed. ECS tuning had it all hooked up with labels when i bought mine
 Pouria Savadkouei
 Michael S. Palmer
MC Hammered
May 29, 2007 09:26 AM
MC Hammered
May 7, 2007 10:22 PM
MC Hammered
A4 (B7 Platform) Discussion
May 7, 2007 10:17 PM
Clout
Jul 22, 2002 08:11 PM
audiohs
Jul 15, 2002 06:04 PM
