Rough downshift
Old Oct 25, 2004 | 03:52 AM
MontcoPaA4's Avatar
New Member
Default Rough downshift
My 2001 A4 ATQ 2.8 clunks as it downshifts to first when coming to a stop...but only after the car has warmed up after 5 or 6 miles of driving, and also clunks when you go on or off the gas at speed when driving.
Did a search, and saw some comments, but I'm still confused. What have you done? Also, a guy at work with a new Passat had the same problem. He told me VW reprogrammed the transmission's software. Is that something to work with my Audi?
Old Oct 25, 2004 | 05:17 AM
Justin517's Avatar
sounds like motor mounts to me, where is the sound coming from? front back middle etc...
Old Oct 25, 2004 | 05:50 AM
por911's Avatar
Default Rough shifting.
How many miles on the car? I 2nd the motor mount suggestion. I replaced ours at 64k, they were absolutely shot. You may want to change your trans fluid/filter (if Tip car). You can recode the trans with a VAG-Com. Good Luck.
Old Oct 25, 2004 | 06:23 AM
MontcoPaA4's Avatar
New Member
Default Re: Rough shifting - ok how to check mounts?
Car is a 2.8 quattro tip with 33,000 miles. Would mounts go that fast, and why does it act up only when the engine's warmed up?
Is there a way I can check out the mounts myself? I don't have access to a lift, but have a good floor jack and also tire ramps.
Old Oct 25, 2004 | 07:54 AM
por911's Avatar
Default how to check mounts?
If you can get the car up enough to remove the belly pan, you'll see the bottoms of the motor mounts. If you see a blackish/purplish substance(fluid, could be dried)on the bottom of the mounts then its time to replace them. The fluid is , and has leaked out of them.
The rough shifting when its warm is another issue. That rough shift or slamming into gear when its warm is not a good indicator for the Tip gearbox. I would change out the fluid and filter. That should not be happening at 33k.
Replacement of the mounts on our car made a "huge" difference, felt like a new car again, no vibrations. When those mounts go, they really translate alot of noise/vibration through the chassis. Good luck.
Sahbi BG
A4 (B9 Platform) Discussion
Apr 22, 2019 09:58 AM
RPortela
95
Sep 25, 2009 09:15 AM
forcefedfreak
9
Nov 2, 2007 07:19 AM
zamicus
Mid Atlantic Discussion
Apr 1, 2005 09:20 AM
V6QuattroFanatic
Jan 22, 2005 04:38 PM
