S4 springs vs A4 springs (help)
What are the differences between these two spring sets???? Is the ride height at all different? Can the stock S4 springs be mounted on the stock A4 shocks? Is it worth doing performance wise?
Any thoughts would be appreciated.
don't do it.......S4 springs are not a good upgrade for your car.......
They are only slightly stiffer and lower than the "non-sport" A4 suspension, and not as low or as stiff as the "sport" A4 suspension.
If you currently have the non-sport package, you're better off getting the A4 sport package. If you currently have the sport package, the S4 springs would actually raise your car and make it softer.
Also, if you have a 1.8, the S4 spring rates are such that the front of your car will sit too high, since the S4 is much heavier.
Don't do it.
Don't do it.
Anyone have S4 spring/struts on A4? Do they use the same struts as stock A4 sport springs? Bad idea?
b5t
07-29-2004 07:03 PM
Trojansruleucla2
02-22-2003 08:50 AM
gkeeper
02-22-2002 10:10 PM
djnelsen
11-26-2001 09:47 AM
