Scan tools from ECS
Old Mar 23, 2012 | 06:58 PM
prijedor's Avatar
Default Scan tools from ECS
I bought 2001 A4 quattro 2.8 about a month ago.Will be getting Bentley on Monday and wondering about these scan tools from ECS if they are good investment.
Has any of you guys used these:http://www.ecstuning.com/Audi-B5_A4-...ls/Scan_Tools/
Friend of mine has ACTRON OBD II scan tool and these seem very similar.
What is the difference between these ECS tools and Ross-Tech Vag-Com?
I am not sure that i can afford spending $350 on Vag-Com at this point.
Old Mar 23, 2012 | 09:15 PM
Oneplank's Avatar
The Vag-Com is awesome. Adaptation, output tests, measuring blocks, graphical output, I could go on and on. I not sure what the Actron units can do, but they certainly cannot match the display of a laptop.
Vag-Com software is updated regularly, and if the anything changes in the hardware (e.g. the development of CAN) Ross Tech has a upgrade program. Add on top of that a huge helpful user base and the answer is simple.
Save the money you would spend on the Actron and put it to a Vag-Com, because you are going to eventually upgrade to a Vag-Com anyway. If you are going to wrench on your Audi, you are going to need the right tools.
Old Mar 24, 2012 | 05:26 AM
mtroxel's Avatar
You can diagnose far more with a VAG-COM. I could go on and on about all the things it will tell you that OBD won't. And it's not necessarily $350. I got this interface for $71, and paid Ross Tech $99 to activate my VAG-COM.
http://www.obdtool.com/default1.asp
Old Mar 24, 2012 | 06:17 AM
Oneplank's Avatar
Just remember, if you upgrade to a newer vehicle (ca. 2006) with CAN architecture, you will need to buy a Vag-Com. The $170 spent is half the price of the genuine article.
Old Mar 24, 2012 | 08:15 AM
prijedor's Avatar
Thank you all for your inputs.I will definitelly be gettind OBD tool and soon after $99 Vag-com.Since i can't really carry laptop with me all the time i might also get V check scanner and keep it in the car.
Old Mar 24, 2012 | 08:21 AM
prijedor's Avatar
Default On emore thing!
Will i be able to use this OBD tool when replacing ATF for checking temperature?
How precise will this tool be for pinpointing problems ?
Old Mar 24, 2012 | 12:58 PM
mtroxel's Avatar
Yes, it will tell you the exact temp.
For example:
You can see exact readings from your MAF. Or, not only does it tell you which ABS sensor is causing your problem, it will tell you the speed each wheel is turning.
You can reset service reminders, or reprogram it so the things don't come back on at all.
Old Mar 24, 2012 | 02:52 PM
5v/cyl's Avatar
I have the V-checker basic and it is good quick and easy scan tool for Audi's. Will check all systems and modules for errors plus reset oil/service lights. Will not give real time sensor data. The V-checker pro will.
I also have a VAG-Com for the more detailed stuff and more powerful diagnostic tool.
These 2 together are nice since I keep the V-checker in the garage toolbox and don't have to get the laptop out for a quick CEL check or oil/service light reset.
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 24, 2012 | 06:33 PM
Typ89's Avatar
Why can't he buy the aforementioned OBD-II cable from ECS and use it with Vag-Com 409.1? It says it's compatible. Am I missing something?
A-U-D-I 23
Audi 100 / A6 (C4 Platform)
10
Aug 2, 2008 08:27 PM
skl1
VAG-COM Discussion
Jun 30, 2004 03:11 AM
TTRicks
Mar 20, 2003 05:53 PM
.burn.
May 14, 2002 10:56 AM
a4neil
Feb 17, 2002 11:36 PM
