It seems my rear brakes aren't working that well. Missing breaking power and car tends to dip more.
Anyone experienced this before?
I am using mintex reds on stock rotors.
Was working well the first 5K or so.
Hey Liam, I got a Q for you re: K04
Do you run less boost when it gets cold? I notice that on my car, I run only 12-13 psi when it's cold out compared to almost 18 psi during the summer. Is boost cut back as dramatically in the K04 software? Thanks a bunch.
less boost for sure...not sure how much though
I think 13-15 is about right.... it's been warmer these past few days, so it's been a little higher
I don't check the boost much anymore when driving around the city. I have different driving "settings" ...
grand ma setting: 5psi throttle (also known as fuel-saver setting)
normal city setting: 10psi throttle
ticket-o-matic setting: wot
its a direct transplant. get used S4 caliper/bracket from salvage store, i also used used rotors
and it felt great. now i have new A8 slotted rotors/brackets - slightly bigger but feels the same as the S4s. i will probably switch to S4 rotors for track
