Shifting question
Old Nov 23, 1998 | 07:08 AM
Fergus Hammond
Guest
Posts: n/a
Default Shifting question
When I was driving a Land Rover, 1st gear was usually useless (at least, for around town; great off-road 'though!). Starting in 2nd was pretty much standard. <p>Obviously, the A4 is totally different. But is staying in 1st still a bad thing? An example:<p>Going up a hill this morning, my girlfriend changed into 2nd at around 3000 rpm, as she's learned to get out of 1st as soon as possible.<p>Would she have been better to wait until around 4000 rpm? And if so, is this generally a good idea? Obviously, going up a hill is different from driving on flat roads but, in general, when do you guys changed out of first? BTW, this is in a 2.8 30v.<p>Any suggestions to help out a new Audi driver would be much appreciated.<p>fergus
Old Nov 23, 1998 | 09:13 AM
EricB
Guest
Posts: n/a
Default Re: Shifting question
Hi, Fergus. I just got my car in April, and it is my first manual transmission vehicle. I climb a pretty good hill every morning on the way to work with a couple of stop signs on it. I usually go up in 3rd to keep the RPM's in the 2-3K range. From the stop signs I usually accelerate to about 3500 RPM before shifing, as opposed to 3000 RPM for non-sport driving on level ground. Hope this helps.<p>EricB<br>98 1.8TQMS
Old Nov 23, 1998 | 09:17 AM
Andrei D
Guest
Posts: n/a
Always use your 1st from standstill! It's why it's there.
Old Nov 23, 1998 | 10:19 AM
AlexS
Guest
Posts: n/a
I usually shift to a higher gear when the little needle on the tachometer nears the red zone.<p>Alex
Old Nov 23, 1998 | 10:25 AM
Fergus Hammond
Guest
Posts: n/a
That wasn't my question; read again.
Old Nov 23, 1998 | 11:10 AM
Jeff M
Guest
Posts: n/a
Default 4000 RPM
4000 RPMs on both of my cars, A4 and a Montero Sport. No negative repercussions.
Old Nov 23, 1998 | 02:18 PM
Ray Calvo
Guest
Posts: n/a
Default General: shift at lowest RPM at which the next gear is not lugging
Been largely following the above advice for about 28 years and 800,000 miles of stick shift driving in normal conditions. I generally don't like high RPMs in 1st - harder on the tranny, driveline and clutch. This generally might be (as Iremember), shift at about 3000-4000 to result in about 1500-2000 in next gear. On a hill start, might increase RPMs somewhat for added power. If you have to floor it in next gear due to too low RPM, you shifted too early. This is a 2.8 Avant, for info.<p>Now, on autocrooss starts, all the above goes out the window.
A4B8PERO
A4 (B8 Platform) Discussion
Mar 15, 2019 06:44 AM
tosehee
S4 (B8 Platform) Discussion
47
Jul 18, 2013 02:02 PM
lig
16
Mar 25, 2004 10:56 AM
magiciansampras
Apr 24, 2000 07:45 PM
MatthewK
9
Nov 23, 1999 06:35 PM
