Snap oversteer
Car is on stock sport suspension and tyres with 38F and 40R psi.
Yes i know if i applied some throttle i might've straightened her out...but in those split seconds my mind just went blank..
So apart from driver error.... will anything else help prevent this in the future? is the tire pressure too high? will suspension help make the car feel more planted?
TIA - help the newbie out
J
2: as previous people have mentioned, this is still easily preventable with a bit more skill. When you swerve quickly like that to change lanes, you should really be making two inputs: turning the steering wheel to avoid the intial obstacle, and then returning it to the straight ahead position. It sounds counter-intuitive, but you really don't have to steer back the other way to get the car going straight in the new lane. And as you experienced, steering the other way can cause a pretty violent snap oversteer. Here's why:
When you first steer to avoid the obstacle, you're compressing the springs on the side of the car opposite the direction you're turning (the way your car is leaning). When you've avoided the obstacle and start to steer the other way, the weight of the car shifts, and the springs release all that pent-up energy and make the car snap back the other way. If you add a far amount of steering input at the same time, you're going to get snap oversteer every time.
The key is to anticipate that weight shift, and not to steer too much.
I teach at my local BMWCCA chapter's advanced skills schools, and this is one of the exact drills we do. They're incredibly helpful, and lots of fun. You should see if your local Audi or BMW club offers the classes... it's usually a day, $60 and a thousand miles of wear on your tires :-) but well worth it.
Finally: I don't view a stiffer/better suspension, OR better tires as the right fix for this. Your car already has the stock sport suspension, which should be more than enough for all street driving, and you spun because you didn't manage the weight transfer, not because of a lack of ultimate grip. Spend your money on building your skills first.
The second issue is a little more difficult to assess. The tires. While there might be good tread left on them, tires will harden as they age and heat cycle. As they harden, they trade off some of those grippy qualities they had when they were new. And if the rear tires are more worn (or older) than the front tires, that's a contributing factor as well. It's also possible you had a set of cheap tires optimized for 100K treadlife. The 2 psi increase in the rear is okay. It does exaggerate oversteering tendencies. But these cars don't oversteer very easily unless you do something drastic to force them to do it (like you did). Generally, I wouldn't be alarmed by +2 psi in the rear. I would focus on the tires and the driver.
1.Every object in a state of uniform motion tends to remain in that state of motion unless an external force is applied to it.
2.an object with a certain velocity maintains that velocity unless a force acts on it to cause an acceleration (that is, a change in the velocity). force=mass x acceleration
3.For every action there is an equal and opposite reaction.
*the third one is most important for your situation. If you are gonna get jerky on the wheel, your car is gonna react in that way.
