Stereo code lock problems
Old Oct 2, 2003 | 08:10 AM
Vederandaia's Avatar
New Member
Default Stereo code lock problems
I bought a used 99 A4 avant and the Symphony stereo was locked in safe mode. I have the manual for it with the code, followed the instructions to unlock it and it didn't work. So I went to the dealer, they pulled the radio and indeed it had a different serial number than what was listed in the manual. So someone changed the unit. They generated a new code, and that didn't work either. They told me maybe it was locked up from guessing wrong twice. I left it on for the prescribed hour and tried again. No workie. They said there might be a bigger problem with my unit. I suspect they may have made a mistake in the code generation. Has anyone had experience with this? Do the Symphony units ever get into a state where they cannot be unlocked, even with a newly generated code?
Old Oct 2, 2003 | 08:30 AM
audiski's Avatar
Member
Default Try the audio forum and this if you don't get any help.
<ul><li><a href="https://www.audiworld.com/search/">https://www.audiworld.com/search/</a</li></ul>
Old Oct 2, 2003 | 10:00 AM
AwdiA4's Avatar
Default ultimately, you need someone to do their job right
I had the same thing happen to me when I bought a used 986. The radio was replaced w/o me knowing and the radio code supplied in the manual didn't work. Luckily, I only had to fax over my license to the dealership and they were able to give me the correct code based on the serial# that I provided them from the Becker radio. Is this a dealership or Vic's local car lot? Whatever the case, somebody has to remove there head from their *** and produce a valid code. good luck.
a4avant99
Sep 28, 2008 08:02 PM
- GT Style -
Jul 12, 2007 07:30 AM
audilvr
10
Jan 11, 2007 07:50 AM
Auditaki
Audi Original "S" Cars
May 24, 2006 01:22 PM
C. Redl
Apr 19, 1999 02:58 PM
