Stock 1.8T 170HP non-linear acceleration
I just got the 2001.5 Passat with the updated 1.8T engine. I'll bug you guys cause there isn't much experience yet on vw vortex and you have had the 170 HP engine on the A4 for a while longer.
Right around 2800RPM it feels like the accelerations levels off, and then around 3000 it seems to take off again. Sometimes it does it again around 4000RPM. I've also noticed surging when I'm in first gear.
Anybody determined what is causing this non-linear acceleration? Is it just the way it is or is there a problem?
Thanks
Thanks
The '01 A4 has a hesitation around there...
It is felt mostly in first and second at part throttle and more obvious with a chip. Someone said it was a bug in the ECU code, something about having too many things to do at once (I guess VVT starts changing around there).
The torque curve is pretty flat from 2000-5000 RPM in stock mode so it shouldnt be a boost issue unless you have a wastegate problem or the bypass is opening up by accident (farting sounds accompanies this).
sorta noticed this.... however try this:
in 1st/2nd (second is easier to feel) give it more than average throttle, then ease off, then give it about that again. You will feel what you described. However, if you apply constant pressure all the way through the turbo's range, I don't think you'll feel it. Try that and see if you can tell a difference. I have a 01.5 A4 and it only feels like it hesitates I think because I spool the turbo, then kinda lay off the throttle and the boost is kinda wasted, then when you ease back ON the throttle, that boost isn't there and it has to spool again.... any ideas? Just my thoughts on it...
AwdiA4
09-20-2002 09:22 AM
Evzen
Performance and Tuning
13
06-06-2002 03:53 PM
Michael D.
04-28-2000 08:47 AM
