Strange engine noise (almost like diesel)
Old Jun 1, 2005 | 04:04 AM
cigarash's Avatar
New Member
Default Strange engine noise (almost like diesel)
Need help with strange noise from 98 A4 Q. with 84K ( timing belt has not been changed) Noise started this morning,appears to occure at front of engine just below plastic engine cover, Noise increase with engine speed even in neutral.its not a sharp metalic sound.Oil level ok. Could it be the timming belt breaking appart
Old Jun 1, 2005 | 04:17 AM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
Which engine do you have? It sounds more like the cam chain tensioner than anything..
Old Jun 1, 2005 | 04:54 AM
eug (MK V)'s Avatar
Elder Member
Default Had same thing...check alternator...mine became noisey as ****
was even told it sounded like a deisel. Had it replced
Old Jun 1, 2005 | 05:20 AM
Weekender's Avatar
New Member
Default At 84K you might want to change that timing belt as well...
Mine snapped at 94,000. I would have had it changed at 80K but my mechanic gave me bad advice.
Old Jun 1, 2005 | 05:28 AM
Solaris's Avatar
AudiWorld Uber User
Default I would actually start here. Don't bother diagnosing any noises until the TB job is done
if it isn't any of the timing components making the noise, you still run the risk of losing your head or engine. If you make costly repairs, then it fails, you just kicked yourself square in the crotch.
Old Jun 1, 2005 | 06:19 AM
BigEd's Avatar
Member
Default Welcome to the club?
<ul><li><a href="https://forums.audiworld.com/a4/msgs/2338033.phtml">click</a></li></ul>
pmc_73
Mar 6, 2012 10:55 AM
ajeaton
Jan 15, 2008 09:40 PM
Kimbo Slice
Nov 11, 2005 11:30 AM
Ziggi@8
Dec 21, 2001 06:43 PM
