Stupid question....
Hypothetical answer...
A taller tire has a larger radius and by that will produce a "smaller gap" as you put it.
However a tire taller than the 12.45" radius of the stock and optional tires on an A4 will have significant negative effect on the cars performance. The 225/55/17 tire you propose is almost an inch in radius taller and will be about 7.5% too large. In fact I am not sure if it will even clear basic suspension components.
Depending on offset of the wheel and willingness to roll fenders...
...you can get 235 widths in there. You need to maintain the stock overall diameter as closely as you can and that will define the ratio you can use with a given width and wheel diameter. Check this URL for a way to do some figuring...<ul><li><a href="http://www.miata.net/garage/tirecalc.html">http://www.miata.net/garage/tirecalc.html</a</li></ul>
something you should know...
225/45 17 =
width of the tires / the height in % respect to the width
you cannot use the thicker tire to filled up the fender gap because if you run say 225/75 17 (exaggerate)
you'll have too much sidewall which in turn when you are turning, your tires will twist, hence comprimising handling.
digitalskate
02-26-2005 01:35 PM
UseTheS4ce
13
12-17-2004 08:13 AM
StrikerNo9
Wheels & Tires Discussion
09-11-2004 07:01 AM
muvment
02-06-2003 07:14 PM
Norcalguy
12-10-2001 12:20 PM
