Stupid question on autovation brake pedal installation
I did search the forum - seems to be 2 different opinions. If the 2 holes go "up", how can I be sure to drill where there is enough clearance behind for the nuts? It seems very tight back there because of the wraparound edges on the existing pedal.
Or if the single hole goes "up", and I use the longer bolt through the slot in the existing pedal, what prevents the washer from slipping through the slot. And how the heck can I get a wrench on the nut?
i still have my awe pedals in the box laying around,
i dont have the right size tap and might just sell the pedals but i am not sure yet. not worth the hassle at the time right now for
I installed my Autovation brake pedal with the single hole
facing up. I just used a large washer with a small hole (can't remember what it's called) to span the slot. Getting a wrench on the nut was no problem... One other tip - be careful not to tighten the nuts too much, the bolts are aluminum and they break easily if you over torque them.
daves4
06-28-2004 07:48 AM
ZephyrS4
05-21-2003 06:49 PM
S4inSoFla
12-07-2002 04:09 PM
