A Summary about the difference between Quattro and other 4 wheel drive vehicles. Please!!!
Guest
Posts: n/a
Re: A Summary about the difference between Quattro and other 4 wheel drive vehicles. Please!!!
"Road & Track" had a good description about 10 years ago in an article they had. In regards to to the Sube vs. Audi differences, as far as I know the Sube is largely set up to put about 95% power to the front wheels; only when these start slipping is power sent to the rears. I think they cannot go beyond a 50/50 power split.<p>The Audi iss set up, to my knowledge to, give a 50/50 split under normal conditions; if front or rear starts slipping, will redisitribute power to front or rear wheels that still have grip, up to a limit of 95/5 or 5/95 to front and rear. Audi useds a mechanical power converter (Torqsens?) to redisitribute this power. Think that the viscous coupling on the Mitsubishis accomplish the same thing with a fluid torque transfer case.<p>Which is best? Personally, think either the Mitsu or Audi is Superior over the Sube.
Guest
Posts: n/a
Wrong. Subarus come in 50/50 split as well (more)
Subarus with manual transmissions start at 50/50 and go from there. Subarus with automatics start 90/10 or thereabouts and adjust from there. I believe the manuals are entirely mechanical (viscous) and the autos are electonically controlled via the transmission. I had an Outback auto (replaced by an A4 1.8T) and have a manual Impreza RS. I definitely prefer the 50/50 split.
Guest
Posts: n/a
Between quattro and SUVs is easy...
Most SUVs are manually switched into and out of 4WD. So quattro is always on, which helps in those unexpected situations. SUVs with 4WD tend to not have a differential between the left and right side, so you should not be driving in 4WD mode unless the tires have slippage, or you will damage the tires and axis.<p>The difference between quattro and Subaru or any full-time 4WD systems (like the Mercedes M-class, or Ford's top-of-the-line system, or the new Jeep system), I can't help you with...
OttawaA4Can
01-02-2003 03:16 PM
Animagix
06-25-2001 08:48 AM
Pelican18TQA4
02-16-2001 09:53 AM
