Suspension question
Old Feb 26, 2004 | 04:01 PM
silverA4TQM's Avatar
Junior Member
Default Suspension question
I had H&R race with bilstein adjustables on my 99.5, I am thinking about putting them on my 97. Now the thing is that the 97 is stripped and weighs 900 pounds less than the 99.5. Will this affect the ride height with the bilsteins on the lowest pirch? Thanks
Old Feb 26, 2004 | 04:12 PM
Digit@lex's Avatar
AudiWorld Expert
Default Wow. 900 lbs is a lot. I'd have to say yes.
I think it will rise a bit but not drastically.
Old Feb 26, 2004 | 04:14 PM
Junior Member
Default What not drastically?
Can I get more groves on my bilsteins?
Old Feb 26, 2004 | 04:21 PM
SilverA4Fun's Avatar
Default yes weight plus or minus will have impact on compression, ride height and dampening...
most springs are designed based on a range of weights, since you start off with static weight both car full and empty and then you add dynamic forces to the equation. Then you factor in spring rates and how the change in weight is distributed around the car. You'll honestly not notice too much of a difference in the front height since other than A/c there isn;t too much heavy stuff that would be removed other than the battery which you can relocated more towards the rear of the car. Clearing the trunk and back seat of stuff will yield a slight increase of height do to less unsprung mass on the springs. Also if you add a cage that will add some weight, this is typically neutral since it ends up being between both axles. You should try to balance the weight not just front to rear but also side to side, since adding a driver and seat is easily 200lbs to the left side of the car, its called corner balancing. Hope this helps.
Old Feb 26, 2004 | 04:24 PM
Digit@lex's Avatar
AudiWorld Expert
Default I'm sure you can get more grooves but I have no idea what kind of a raise a 900lb lighter car
will yield.
Old Feb 26, 2004 | 04:28 PM
Default A stock A4 1.8t is about 3100lbs, so shaving almost a 3rd off changes the dynamics
of all forces not just ride, but braking, acceleration and even lift or lack of downforce. A lighter vehicle is more apt to not hydroplane than a heavier one, especially with wider tires. Downforce creates downward pressure with out the need for static/physical weight, plus its variable more dowan force with speed and better traction.
Junior Member
Thanks, makes sense
Old Feb 26, 2004 | 05:22 PM
odelay12v's Avatar
Default i have heard of people takeing it to a machine shop and putting it on a lathe..
put as many groves as you want in theory..
 Michael S. Palmer
Old Feb 26, 2004 | 07:26 PM
Junior Member
Default Awsome, I am going to have to do that, I wanted it lower than the lowest anyways
Thanks
tehaudi
Oct 30, 2007 02:35 PM
boxster02
Mar 8, 2007 05:25 PM
Mr. Bungle
Nov 14, 2005 11:33 AM
emerged
May 22, 2004 09:16 AM
trojansruleucla
Apr 29, 2002 08:38 PM
