Swaybar data
Swaybar data
Does anyone know the differences between the front sway bars on a 01 A4Q? I ordered without the sport package since I knew I would put on new wheels and shocks/springs. I am already planning on Neuspeed 22mm rear bars, but Im not sure about the fronts... If they are the same as on the sport, then Ill wait to see if I need them, but if they are weaker than the sport, I have a feeling that the handling will be 'mismatched' to say the least... I have found out that they do indeed have different part numbers, but that could just be for bookkeeping for all I know...
Thanks
Thanks
Front "sport" sway bar is different than the "standard"....
....it's the same diameter (29mm comes to mind) but the sport bar is solid while the standard bar is hollow.
