switchblade
Old Jan 24, 2005 | 05:02 AM
jpayeur's Avatar
Default switchblade
i bought a switchblade key for my 97 A4, but am having a problem programming it. i searched the srchives and found someone else that had the same problem but nobody was able to help with a resolution, so i am trying again. these are the steps i followed.
1. turn key 1 to on in ignition
2. lock drivers side door with key 2
3. press unlock on the remote once
4. lock then unlock the door with key 2'
5. remove key from ignition
all steps work when programming my regular remote, but when i use the switchblade remote the the lights flash, but when i remove the key from the ignition and try to unlock it again, the switchblade remote does not work.
HELP!!!
Old Jan 24, 2005 | 05:22 AM
CK:1.8T+Rabbitâ„¢'s Avatar
Default Are you waiting after pressing unlock the first time?
Here's how I know it.
Put original key in ignition and turn to on position. Insert new key in door and turn to unlock. Wait about 5 seconds. Press unlock on new key. Lights should flash. Remove original key from ignition. New key should work.
Old Jan 24, 2005 | 05:28 AM
jpayeur's Avatar
Default Re: Are you waiting after pressing unlock the first time?
i will try that, thanks. the weird part is the lights flash, and it seems like it was successfully programmed when i tried it the other way.
yk7209
Feb 16, 2016 12:54 PM
Chris(DE)
Sep 25, 2006 07:53 AM
Berf624
Feb 6, 2006 05:37 PM
Mr. Head
Jun 19, 2004 06:29 PM
