syncro leaves A4 in driveway
Guest
Posts: n/a
Great morning S. Ont. 10 + inches snow. A4 gets stuck twice in 20 feet. Daughter's 1992 Sycro stick plows out no problem. Roads not plowed , pushed snow with spoiler and bumper. Audi has stock Dunlop 8000 -not M&S. Passat has Michelin 195-15 X M&S 330 snows. Obviously time to put real shoes on Audi. Advantage probably goes to Passat even with equal tires as it has traction control at low speed.<br>PS-- didn't take BMW out of garage. To answer earlier post- with BMW traction control (AST+"automatic stability control + traction") -when slipping occurs you hear and feel antilock brakes working (plus idiot light on dash flashes) Engine power reduces- wheels keep turning jerking and car sits. Ross
Guest
Posts: n/a
no problem in To
With Observe winter tires (195/65/15) quattro had no problem plowing through the snowbanks the plow left this morning. I even went for a joyride last night in the midst of the storm. Car handled extremely well. Time to put the winter boots on.<br>
Guest
Posts: n/a
downtown To: Geo Tracker stuck, no ground clearance
i have not even tried to leave my garage. A geo tracker got stuck (not enough ground clearance).<p>I don't think traction is a problem, but ground clearance is (stock suspension)<p>i will try later today/<p>1996 a4 2.8 qm<br>
Guest
Posts: n/a
Re: syncro leaves A4 in driveway ... was it a quattro?
You never said if you A4 was a front-wheel-drive or a quattro. Also, you stated, "Advantage probably goes to Passat even with equal tires as it has traction control at low speed."<p>A4s also have traction control. Audi calls it EDL (Electronic Differential Locking), which uses the antilock brake mechanism to stop the spinning wheel(s).<p>I've driving my A4 in snow halfway up the wheels, and never got stuck. I have the original equipment Goodyear RSA 205/55-16s which are M+S rated.<p>StevenN '96 2.8 qm
Guest
Posts: n/a
Odd that your BMW behaves so much differently than my 323i. Maybe Minnesota snow and ice not as bad as Ontario's?<p>I regularly pull away from Passat FWD vehicles on snow packed and icy roads here (all are FWD in Minnesota since Synchro not available in the States).<p>My wife's A4 Quattro is much superior to the Bimmer in this respect ONLY on snow and ice. I find the 323i stops and corners better, and this is more important to me.<p>By the way, I have the stock 16" Premium wheels w/ Conti 205/55 M+S tires on the Bimmer.<br>
Guest
Posts: n/a
Oops A4 has edl-Minn.is N.of TO.
I thought edl was like the old posi-traction but I READ the manual. The Passat advantage must have been tires only.<br>Almost all of Minn. is North of Toronto and has tougher winters than southern Ontario.(In spite of all that about "The great white wilderness to the north")<br>My BMW has Michelin MXV4 235-16 stock. They say M&S but are poor even on wet.<br>Ross<br>
