Taking apart the trunk in an Avant?
Does anyone know how to take the back apart in an Avant, I tried this morning and I was unable to take off a couple of screws. Does the Bently manual cover this, the childston didn't or whatever the other one is...
first off, you don't have a trunk...
but on to your question...
you will have to remove all 4 tie down hooks... and to get the sides ALL the way off, you will need to remove the back seat anchor posts that stick out. Haven't removed those yet...
Re: first off, you don't have a trunk...
That is my problem I couldn't get the rear seat achor posts off, they are really in there good or I am trying to undue the wrong thing, there is the screw type thing and nut? If it isan't a trunk what is it?
I honestly have no idea how to remove those posts...
I put an amp back where the CDC was, and I moved as much as I could aside from the posts... and that was enough for me....
I will figure out those posts eventually, as I am gonne get a harness bar for the car, and it goes there.
I always referred to it as "way back" or "tailgate area"... but I was just teasing you about the trunk part...
generally you need to remove every thing around them.
remove side panel, remove tailgate seal in area of loading edge/side panel, remove loading edge, lift front edge of cover for seatbelt and unclip, lift up cover for latch bracket for rear backrest, remove cap, disassemble tie-downs, remove bolts (3), unclip side trim and pull up over belt guide and latch bracket. from bentley. have fun!
marmer
01-22-2018 04:02 PM
UrS4boy
Audi 100 / A6 (C4 Platform)
02-14-2007 09:56 PM
Avantadrive_Original
03-09-2006 06:24 AM
avantster
09-22-2001 04:14 PM
