Tapping noises from the engine?
Old Jan 2, 2001 | 08:06 PM
sparkster's Avatar
Default Tapping noises from the engine?
I am not sure if this is normal, but there is a tapping noise coming from the engine, especially after starting the car up. Is this normal? It is definitly from the under the hood.
Old Jan 2, 2001 | 08:13 PM
geoff's Avatar
Junior Member
Default Re: Tapping noises from the engine?
Are you sure it isn't just your valves ticking? Mine do this and can be heard mostly at idle.
Old Jan 2, 2001 | 08:32 PM
nick n's Avatar
Default Valves
after spark. The lifters are pumping. Be sure to run some 5w-30, esp during the cold seasons.
Old Jan 2, 2001 | 08:35 PM
SDSilver01's Avatar
Junior Member
I had this too when my car was driven cold at night. -- Really slight detonation?
Old Jan 2, 2001 | 09:24 PM
Hawaiiannights's Avatar
Member
its the lifters...perfectly normal...i get it too..you might want to use a thicker oil...
Old Jan 2, 2001 | 10:28 PM
sparkster's Avatar
Thanks All, i am using 10W30, will probably change at next oil service few hundred miles
Old Jan 2, 2001 | 11:11 PM
Clark@turbo5.com's Avatar
Junior Member
Default Lifter noise.
If you hear the noise only at startup for a few secs it is ok and normal. If you car ticks when warm at an idle you should try a thinner oil. Any good 5w oil will do. Running thicker oil will cause the noise to increase as the bleed holes on the tiny hydralic lifters are small. With thicker oil you will get less oil into the lifter there by increasing noise.
Thanks
Clark<ul><li><a href="http://www.turbo5.com">http://www.turbo5.com</a</li></ul>
cardiffkid
4.2 V8 Discussion
Aug 17, 2021 03:43 AM
chairman
10
Mar 9, 2009 09:25 AM
jorge Da Cruz
Q7 MK 1 Discussion
May 31, 2007 09:34 AM
peanutome
Nov 27, 2003 04:04 AM
Austin_A4
Oct 26, 2000 04:58 AM
