is there a certain way in applying touchup paint to chipped paint..
that would yield the best results?
Applying to paint thats been completely chipped off, i dont want it to look all thick and bloby when applying touchup.
how is this safely done?
Thanks
Thanks
<ul><li><a href="http://www.griotsgarage.com/catalog.jsp?L1=L1_1000&L2=L2_1007&L3=L3_15 00&SKU=50860">http://www.griotsgarage.com/catalog.jsp?L1=L1_1000&L2=L2_1007&L3=L3_15 00&SKU=50860</a</li></ul>
text from Griot's Detailer Handbook
<i>You can repair those annoying rock chips and deep scratches that have gone down to the primer. Start by purchasing the correct factory touch up paint from your car dealer. Most touch up paints come with a built in applicator brush. The problem is these brushes are more suited to painting your toenails than applying the proper amount of paint to a small chip or scratch. Again, preparation is key.
Clean the area, removing any oil, grease, dirt and old polish and wax. Use Paint Prep to strip away old wax and grime. If the chip is down to the metal and any rust has begun use our 3M Rust Avenger and Rust Eliminator Tool. The Rust Eliminator Tool uses tiny glass fibers to brush away surface rust and deposits of dirt and wax. Its small surface gets into the chip, avoiding any damage to the surrounding paint. The Rust Avenger delivers a pinpoint application of chemical which attacks the rust and destroys it. It also acts as a primer for paint application.
To fill in paint chips and enjoy pinpoint accuracy and great paint flow use our Touch Up Paint Applicators. You can bend the plastic handle for hard to reach spots, or give you a better angle to apply paint to the chip. You'll even be able to soak up paint with the tips if you've over-filled your chip. Dip the end into your touch-up paint and touch the chip gently with the applicator. If you overfill the chip, use a clean Applicator to dab up the excess paint. If you have clear-coat paint, apply the pigment (color coat) first, let it dry and follow up with the clear coat. Try to avoid driving your vehicle for at least 24 hours after making a repair and wait about two weeks before applying wax or polish.</i>
adminisTerTurbo
06-10-2005 06:55 AM
T-28-Quattro de VT
04-13-2001 08:24 AM
