Transmission Problem
Old May 18, 2001 | 04:36 AM
Jerry O's Avatar
New Member
Default Transmission Problem
On my 96 A4 auto I have transmissions problems.
1) The gear indicator lights are all lighted all the time.
2) If I manually shift into 2 , 3 or 4, it will not change the gear.
3) The trans will not go into D (5th gear), even though the gear shift is in D
4) It seems to shift from first at a higher RPM than before and sometimes I get a hard shift.
I would appreciate any help, thanks in Advance.
Old May 18, 2001 | 05:05 AM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
Default Sounds like it is in "limp mode", unfortunately I don't know how to fix..
my service manual is at home.
Old May 18, 2001 | 05:07 AM
WJM's Avatar
WJM
Tech Guru
i think 5 startups and it clears
Old May 18, 2001 | 05:20 AM
Jerry O's Avatar
New Member
Default Been more than 5 start-up, still doing it
n/t
Old May 18, 2001 | 05:46 AM
WJM's Avatar
WJM
Tech Guru
i dont have a TIP i was just recalling from memory...sorry see if you get a response
Old May 18, 2001 | 08:48 AM
turboprincess's Avatar
New Member
Default Re: Transmission Problem
I had the same problem in my 97 1.8T aut. It happened when I rev'd past 7200rpm in first gear... Anyway, went to the dealer, he reset the computer and the limp mode was gone. I had all gears again including fifth and reverse and the gear indicator lights returned to normal. Other people have had the car go into auto transmission limp mode because of water in the connections between the transmission and the ecu, fixing this returned everthing to normal for them (they still had to reset the computer though). Good luck.
Old May 18, 2001 | 09:14 AM
hsjb's Avatar
Member
I think you have to go for service.
Albatrossboss
9
Dec 19, 2014 09:14 AM
keepmegoin
Audi 100 / A6 (C4 Platform)
Aug 6, 2007 07:23 PM
DaveyKid
13
Jun 25, 2004 02:05 PM
A4_outback
Nov 14, 2003 03:22 PM
WGJ
Aug 29, 2000 05:02 AM
