Trouble removing door molding. The screw that holds it on just keep turning. Never actually comes..
out so I can not remove the trim. I tried both the front and rear (at first assuming maybe just the one rear was stripped) and can not get either out. I am trying to test fit side skirts before painting etc and can not because the molding is in the way..
A comment....
I use a combo of a screw driver with a pick. Use the pick to pull under the screw head so the threads grab and it will come right out. Go easy, as its not difficult to damage the surrounding surface.
Want to remove it, and then cut it using straight edge. And then possibly paint before reinstalling
Either way I am not going to cut the moulding until I instal the painted side skirts. And I can not paint the side skirts until I test fit them!
Projekt 8E
11-18-2003 03:09 PM
Negative459
07-28-2002 12:15 PM
Pizzicato
12-27-2001 11:28 AM
cdagza
06-29-2001 11:50 AM
