Turbo Timer for 2002 VW Question
I have a lot of electronic knowledge and time ago I use to have a Car Alarm Shop.
I have install many Turbo Timer in not VW cars but I have to agree that I can find the way to interface the Fu&% Confort Unit in my VW so the remote control locks the doors.
I check all the wires in the 2 connector/plugs that the Confort Unit have in order to check for ignition power (12v ). I find some wires that keep ignition power when you take the key from the ignition, I cut it to see if the remote locks the doors and DO NOT WORK.
Belive me, I cut a lot of wires at the confort unit and the thing do not lock the doors!
I was from 10am until 5pm, my back hurt and I am so **** of that I donf find the way to do work. Well maybe I just overlook something :-(
Has you has find the solution? Can you help me giving me the wires that I have to interface?????
Thank you for your time and help.
Isaac Fajgenbaum
all i had to do for the security engage while the turbo timer went active was cut this wire...nothing else...
but u have to cut the postive side to the fuse and run it to a 12v constant
the tech article linked explains it really well<ul><li><a href="https://www.audiworld.com/tech/elec31.shtml">https://www.audiworld.com/tech/elec31.shtml</a</li></ul>
